m-i-c-k-e-y
There is another 3.26 driver that has been patched by LHLabs on the signed driver issue. It's out there. Unfortunately I don't have it.
Lastly, for those who are still "waiting" for their LH DAC/Amp purchase to arrive: you should just get a Sabaj A20H with a Topping D10 Balanced DAC and HD58X or HD6XX with balanced cable and call it a consolation prize.
Hey folks. I just set up a new rig and seem to have the Pulse working with Windows 11.There is another 3.26 driver that has been patched by LHLabs on the signed driver issue. It's out there. Unfortunately I don't have it.
Hey All.There is another 3.26 driver that has been patched by LHLabs on the signed driver issue. It's out there. Unfortunately I don't have it.
https://www.head-fi.org/threads/gee...c-amp-by-light-harmonics.687851/post-17413701My Geek Pulse xFi stopped working after recent BIOS & Windows updates. The 3.26 driver which has served me well for years is "unsigned" and can no longer be installed (with Secure Boot enabled). I've searched for Windows generic or alternative drivers, with no luck. Has anyone found a workaround for this problem? This seems like such a minor reason to brick such an excellent DAC.
I posted this previously as the course of last resort.
Send to local repair shop like me... Tell them to use wpt or cardas silver solder... Match exact parts or better if possible...I'll share my other solution to your worries......
Just kidding...USB was busted due to a short on my Revelation Labs custom power barrel cable.
So my solution was a Singxer F-1 connected to its SPDIF. Right now its on the shelves.
So I took another stab at trying to figure out what type of screen is used in this series of dac/amps, and I think it is this one in the 3.3V configuration:
https://www.aliexpress.us/item/2251832646917403.html
Using these older pictures of what is now the "labs" very likely now used for Tesla speaker setups
Have you tried repeating the pairing with the Apple remote? Or simply manually reconfirming knob-control from the menu?I have the same basic issue. My Volume won't change the volume level -- X-fi balanced version. I now have it running Toslink Optical input (via a Topping D10S) to avoid driver issues. This works well with the following caveats. I have to leave it powered on permanently. If it is turned off, such as after a power outage, nothing works. I leave it without the power plugged in for a few days and then turn it back on and leave it on for a few days to fully warm up. Then I hooked it up to my Music Player (Music Bee) and switched the Geek Pulse Xfi power switch off and on, setting the input to Toslink (optical). After doing this several times, I got to a state where I had no Geek Pulse Xfi knob control (including volume), but both DAC and amp would work through all outputs. I can control the Geek Pulse volume via the Music Player volume control via the optical input. Volume control is not very fine in control, but the sound quality of WAV files bit-perfect into the Geek Pulse and out of the balanced XLR to Focal Clear headphones is outstanding. I'm not sure whether this will be repeatable when the next power outage happens. I think that by having it hooked up optically when you initially turn it off then on, it tries to sort itself out and saves those settings. Then when you quickly turn it off and on again the 2nd time, it tries to implement those settings. that's my best guess......
Or use them together...many options with both!!My Pulse Sfi/LPS combo has worked fine until now, with only slight hickups when changing sampling rates or when the remote loses its pairing with the DAC (it is easy to remedy but a PITA nonetheless). The sound is fine, no complains there, but I want to cut the connection with such an unreliable and untrustworthy company. So, a few days ago I bought a used ifi IDSD Neo off ebay and I can't wait to get my hands on it. ifi might be the absolute antipode of LH Labs: Serious, reliable, producing excellent hifi gear who do EXACTLY what they are supposed to do for an affordable price. The moment the IDSD NEO crosses my doorstep I am placing an add for the LhLabs on ebay and never looking back.
How? I can't imagine using two DACs at the same time.Or use them together...many options with both!!
They could positively complement each other...
