m-i-c-k-e-y
4.2Vrms (47 * 2 Ohm)
I am the same with you. Got it from an old data. After many years I can't remember what it meant. Maybe its 94 ohms since SE output is 2.1Vrms @ 47 ohms.
O dear, Stuck Limo has gone AWOL again.Ok Stuck Limo, time to ask again: when are our Pulse Infinity and LPS orders arriving?
A rhetorical question, of course. Because from time to time LH Labs still gives assurances about delivery of outstanding orders, but nothing happens.
I would prefer if you had the courage and honesty to tell us the truth - that delivery won't happen.
It's been lie upon lie, starting in 2013 when we placed our original orders. LH labs is a company that took our money, is totally inept, and deserves to be rebuked by the entire audio community.
Does anyone here have a link to the 3.26 firmware? It appears the link on their official website is dead
3.26 is the ASIO driver for the computer to connect to Pulse, not the Pulse itself
DSD256 needs a custom firmware on the Pulse itself. I sadly dabbled in doing so when it was not recommended. On the website there is a note that Pulse Infinity units have a custom firmware by serial number. So I can play dsd256 but there is a loud pop right before playing a file. USB stability overall is very bad. I’ve had to stop using it because it disconnects. I would’ve loved to have a backup of my unit’s original firmware but I dont.
So I've downloaded the latest firmware and can now play DSD128 natively just fine but my Jrivermedia center (v20.0.132) keeps crashing when I try to play DSD256. Anyone have any clues as to why this might be? I am running it via ASIO
Was one of the early beta testers for the DSD256 firmware back in October 2015.
Mine is Main 3.0, MCU 2.4 forgot USB...
Here is my DSD256 X Infinity firmware. Please use as a last resort if stucklimo could not provide you one. Incorrect flashing might brick your unit. And support now is inexistent. Haven't got feedbacks to persons I have shared my firmware with if it worked. Nobody got angry also so maybe...
https://drive.google.com/open?id=1pdRTaiK5FRCGDSX0Vrkpw6AStoRKFC8w
When flashing use the DFU utility that comes from your windows driver. If you don't have one, use that is found on this driver:
https://drive.google.com/open?id=112gnZ1jiGZez9ttERBU-SBQ_kvf0nZ7C
DSD256 works only on NATIVE mode NOT in DoP.
