m-i-c-k-e-y
Make some noise...bug them to death!!
In cyberspace no one can hear you scream...
Well, I'm screaming now in response to the Indiegogo update sent today about the HPA. I'm waiting on both an HPA SS and an HPA Tube, originally perked in February 2015, so at least it was good to finally hear something about them after more than 3 months since the last update.
Here's the problem: Larry announced that the HPA is now going to require a 15V supply, but LH Labs previously told LPS owners to upgrade to the LPS4 in order to drive both the Pulse Infinity and the HPA. Now I'm stuck with two LPS4 boxes, having paid $170 each to get 3 additional 12V outputs that are now totally useless.
I already submitted a ticket complaining about this and asking what they plan to do to fix the mess this decision creates. Converting some of the outputs of the yet-to-be-released LPS8 does absolutely nothing for existing LPS4 owners.
They sold us LPS4's, with he promise of completing a Pulse based music system. Then they change the design parameters (Voltage Requirement)of the HPA Tube. Is there anything we can do about it?
Interestingly, more often than not, if I do not turn the pulse off, all is good. I know some say to never do this, but I go some long periods between using the Pulse. I just can't justify leaving it running all of the time.
BTW I use several other USB DACs with no issues using the same cables and ports on the same machines.
Firstly, this thing is a bit flaky and doesn't work as well as other USB DACs I've had. I think that's a common understanding across the Pulse threads.
On your long duration, though, I often go 2-4 weeks without using my Pulse, but I leave it on and connected all the time. The parts inside aren't going to wear out in its lifetime and thermal stability is good, so why not? Leaving the AC for a couple hours uses more power.
I consider it to be quite wasteful .. for energy use, and ageing of the electronics (heat kills micro devices.. check test data).
I can't understand why ..given adequate driver compatibility, it should not be able to be turned off and restarted ..and still talk to the source.
In any case, I do not think that what you do has anything at all to do with my situation and my expectations. Not to be harsh, that is what is.
If it can't do this, fine, I get rid of it. But it really should be able to, as large numbers of other DACs, some lots less expensive accomplish this regularly.
IOW, no excuses. It sucks!
The common wisdom (often not at all accurate) was that it needed to be left on to stabilize the clocks... and supposedly sound "better" . Doubtful at best.
There is no reason to require it be left on just so I can connect it to my source... None! If the thing is designed correctly and has working drivers, that is.
