- Dec 27, 2010
I have an HTC 10, uses usb c. Bought some cables that I think are OTC (not sure), haven't tried them yet. A cable recommendation would be great! Thanks.
mickey so you connect the revive to the phone with a usb micro male to usb c male cable? a special OTG one? that's the cable I'm not sure of.. my phone uses usb c already
On Windows/JRiver, before flashing to DSD256 firmware (Infinity), i have great results using KS (Kernel Streaming). To my ears more grit/body.
valve5425,
Do you think a software problem exists between Foobar 2000 and Pulse Infinity? I switched from MediaMonkey to JRiver 19 when I got my Pulse Xfi in order to play DSD. I noticed that JRiver beat MediaMonkey In SQ playback of PCM. I never had problems w/ JRiver recognizing LH Labs DACS.
OK. I submitted a ticket for the updated firmware. I will let everyone know when I get a substantive response... or get the firmware and drivers in hand.
BTW gikigill, hoe long ago did you make this transaction ?
My Pulse was delivered last year May and I ordered in January 2014.
The different versions of the Pulse have different firmware. The USB problem disappeared after the update and I must admit that the Pulse is a fine piece of kit once properly setup or else it sounds very thin and lifeless.
My pulse is not even recognized as existing by the LHL drivers. At that point Foobar is not running. I have checked, no services, no Trace of Foobar.
Pretty hard to imagine that it is causing a problem if it is not even running.
So it doesn't show up in the "LHL Control Panel"?
Nope.. No sign of it. Once it connects to the driver, Foobar has no problem playing through it.
Assume you've tried the old "uninstall/reinstall the driver" trick?
I meant, how long ago did you submit the ticket to get the upgraded firmware? I think at one point they were doing a better job of responding to tickets... if not actually resolving them in a satisfactory manner. I have an idea that they have reduced there "customer happiness" team.
I got my firmware in 48 hours. I made sure I put in all the details before sending a request.
