Wow...I have not been on the LHLabs forums since fall of last year until today. Seems they really have self-immolated...there are NO users presently logged in! Anyway, I figured it might be more useful if I asked my question here. I have a standard Pulse DAC and I just purchased a small touch screen Windows 10 PC (PiPo x9) to use as a music player. I am using MediaMonkey with the output set to ASIO and it sounds great! I only have one issue: If I start playing an album that is 16/44.1 it plays great. If I then try to play a 24/96 or 24/192 album, it is all distorted, like the bit depth or sample rate is not correct. The DAC display shows the correct sample rate. If I skip ahead a track and then skip back the whole album will play fine. I can then play another album in any format and playback will be fine. It seems this only happens when going from playing 16/44.1 to 24/96 or 24/192. Has anyone experienced this issue? I'm not sure if it's the DAC or MediaMonkey that's causing the problem. Internet searches have not turned up anything.
Thanks!
