Audio Addict
- Aug 5, 2001
You mean the lps cord? or the infinity cord?
The Infinity standard delivery is pretty weak.
The power cord is only on the LPS.
Just to make it extra confusing you can also get an upgraded umbilical power cord between the LPS and the Pulse. There was a group buy a while ago of a nice custom cord - picked up one or two and have used them from the start. Well made cord and nice purple color. Cheers
So after playing some music through my infinity for about 2 weeks now (I am sure I have racked up 150hours on it), I decided to do a quick comparison to my Audio-gd NFB-28 (late 2013).
I have my Pulse Infinity hooked up with my LPS (supplying power only) but I am not using the 2G cable yet.
I am having a difficult time noticing any differences. At times, I do feel the Pulse Infinity extends slightly deeper, and the soundstage seems to be more open/3d like feeling expands. However, it feels so close. I wasn't expecting a big improvement over the audio-gd, but a noticeable nonetheless.
I currently don't own any balanced headphones, but for those that appreciate the sound coming out of the Pulse, do you feel the same way when using the SE headphone input?
I guess I feel underwhelmed after this long wait but perhaps I am doing something wrong.
Cable needs burn in? What the...
Please explain that to me...I'm pretty gullible.
Not again.
Look I'm trying to be helpful based on my experience. It could be all in my head. Do it, don't do it, I don't care. Just trying to be helpful. The advice may be ignored. Thanks.
Not again.
Even Larry mentions 2 weeks of burn-in for the 10G cable so it should follow suit with the other cables as well. For what it's worth, the cable insulation, dielectric, acts as a capacitor which stores and releases energy from and back into the cable and, according to some, the interaction between the metal conductor and the insulation takes time to reach equilibrium. I'm not looking to argue, just stating what others have indicated. Believe what you will!
