goldendarko
- Nov 9, 2013
Honestly, I'll pass on these. LPS it is then.
They will not quit until they've sucked your wallet bone dry!
@ LPS
Why is the LPS's scheduled shipment date in May 2014 with the holiday payment option (3 payments, $299 total), but June 2014 with the normal, single payment option?
Is this a typo, or is this done on purpose?
I'm also planning on using this with my Audeze LCD-2's. I currently use a Burson Conductor, but I want to get a 2nd amp for my computer with the Burson being my main listening amp. I am also curious to know if the Pulse will power the LCD-2's sufficiently as I don't recall the power output every being discussed in this thread.
I'm too lazy to find the post for you but larry basically said these are the improvements from the upgrades in order of biggest change to smallest
Geek Pulse X/S
Femto
LPS
Active components
Passive components
but my friend who is an amateur amp/dac designer suggested the LPS will make a bigger difference than anything else in a system that is otherwise well designed.. so there you go.. two opinions. Also my opinion is that if you can afford the S you may as well get the X, it contains BOTH types of ports and is only 20 bux more.. that way if you upgrade other stuff in the future you can use the xlr ports
That's cool, some good deals on cables, although that USB one for $699 makes my eyebrows raise right off of my head
