Geek Pulse: Geek desktop DAC/AMP by Light Harmonics
Aug 4, 2015 at 11:52 AM Post #8,716 of 13,808
  Hi Guys,
I am new to this gear, Geek Pulse, looks like a long thread with a lot of reviews. I need help selecting a DAC, I am comparing Oppo 105/105D as a stand alone DAC vs Geek Pulse. What are the pros and cons. Please help!
Thanks!
LR
The Geek Pulse and Geek Pulse X are better than the Oppo BDP-105. I knew within 10 minutes of listening to my Geek Pulse (standard) that I was going to sell the BDP-105 and it was gone 2 weeks later. I now use a Geek Pulse X in my stereo and Pulse on my PC for headphones.
The BDP-105 does many other things that are also valuable, so if you're willing to compromise on sound quality to gain a ton more useful features, then the Oppo BDP-105 should still be at the top of your list. When it comes to pure 2 channel DAC capability and headphone capability, there is no contest. Geek Pulse wins.
Aug 4, 2015 at 1:23 PM Post #8,717 of 13,808
If it was me, instead of a BDP-105, I would consider the Oppo HA-1 !
The Oppo 105D is amazing value, and does many things right! but HA-1 is more apples to apples against the Pulse in my opinion. And even still, the HA-1 has many features the Pulse does not and it is very well reviewed.
How does it fare against an Xfi and up with their custom femtos? Good question worth searching for answers
Aug 4, 2015 at 9:49 PM Post #8,720 of 13,808
Aug 4, 2015 at 10:40 PM Post #8,722 of 13,808
Well, there's the Signature, then there's the Signature Special Edition, and then there's the Signature Special Edition Ultimate, and then... :D
Aug 4, 2015 at 10:46 PM Post #8,723 of 13,808
https://www.indiegogo.com/projects/geek-pulse-audio-high-rez-desktop-sound-system#/updates
Seriously, it does look like the Infinity is still available, the Signature is sold out (there was only an offer of 1 Signature on Indiegogo, the way it reads). Still, if you really MUST have one, you could send a message to them, maybe they'd build a second one...
Aug 4, 2015 at 11:35 PM Post #8,724 of 13,808
You're right Doc,
Note that those are chassis 1.0 Infinities.
Aug 4, 2015 at 11:55 PM Post #8,725 of 13,808
Ah right yes! True.. It's only the 1.0 chassi units. I believe they just put them in 2.0 chassis and sell through their dealers?
Aug 5, 2015 at 12:17 AM Post #8,726 of 13,808
I believe they're already boxed up and just sitting so I doubt they're going to take it all apart and put them in a 2.0 chassis.  Reading the latest update, those are 1.0 in no uncertain terms. This is to get rid of EOL units.
Aug 5, 2015 at 1:55 PM Post #8,728 of 13,808
  Hello Audeze LCD (Fazor) headphone owners! What's your gain and volume setting? (e.g. LCD-2f, low gain with high volume)
Hi there, I run on High gain at approximately -41db volume from the balanced output.
Aug 5, 2015 at 3:24 PM Post #8,729 of 13,808
Larry Ho recommends the lowest attenuation possible. So if you are at -15 using low gain, That would the preferred setting.
