Hello everybody,
What do you think of this : https://www.indiegogo.com/projects/geek-pulse-ultra-high-def-audio-for-your-desktop/contributions/new?perk_amt=698&perk_id=2489966
is it a good opportunuity or not ?
how if compared to : GEEK PULSE + HIFIMAN 560 at 960 USD ?
which one is the best ?
regards
sam
The more expensive one is obviously better, while the cheaper one is better value. As it usually is with audio stuffs.
From the reviews of these two tho, it seems that the HE-400i is easier to drive while HE-560 is more power hungry, but better overall.
AKA the HE-400i would probably be fine paired with your portable DAP, whilst a HE-560 needs to be driven with enough power.
Assuming that the Pulse can drive the HE-560 comfortably, that should be the better pairing.
I'd say grab that if you have the budget to, it's easily the best improvement overall, much better value than any other upgrade you could pledge for in the campaign.
