syn80
Hello Syn80,
I got exactly the same issue that you got since the very beginning.
Did you figured out how to solve this issue.
Where did you buy the new Jack socket and what is the reference ?
Thanks in advance for your help and inputs.
Regards
Cedric
I have yet to find the last solder point. All I have is ground and either Left or Right.
On Amazon I found pretty much the exact same socket. I don't know if links can be posted but if you go to Amazon and type "uxcell 6.5mm Socket 4 Pins Audio Stereo Jack Connector" you should see It sells for $2.54. You may find them elsewhere but this was where I found the closet match (the original had gold plating around the socket hole).
I would have liked to use this style if I knew the alternate solder points and it lined up well in the case and front hole, but I'm unable to make any progress until I find solder points.
