tj28
- Dec 8, 2011
A new iteration of FX-Audio's flagship-class DAC-X6 has been released for 2016. I have yet to find any audiophile reviews for this model in English so the value of this DAC is still unknown, however, it looks very promising.
Technical Specifications:
Standard Input Interface: PC USB / coaxial, fiber optic (with toggleswitch)
Standard output interface: 6.35mm headphone output base linestandard RCA connectors
Color: Black
Panel Color: Black / Silver(pls tell us which the color you want,or we will send the color randomly)
Line level output: RMS 2V
Perfect driving 32Ω-600Ω headphones
Output power: 90mw / 600Ω, 180mw / 300Ω, 450mw / 100Ω, 610mw / 62Ω, 910mw / 32Ω, 1000mw / 16Ω
SNR: ≥105dB
Distortion: ≤0.001%
Frequency response: 20hz-20khz
Adapter Voltage: 100-240ACV
Machine power / adapter output voltage: Dc12V 1A above
Machine dimensions: 146mm x 98mm x35mm (including protruding parts)USB-tier manufacturers in Taiwan with a stable performance VIAVT1630, high
resolution, under a wide range
of frequencysupport 44.1K-192k 24BIT 16BIT mode mode 44.1K-96K, Android4.2.2 system can support OTG mode (need native system),support Applle
phone tablet, etc. OTG mode,
DAC part is fineCS8416 + CS4398 LPF output using OPA
There also is the DAC-X6J for the Japanese market, and from what I can tell based off of Google Translate, there was something incompatible with the Chinese version in regards to voltage and amperage requiring a different revision for Japan.
I think a few Head-Fi'ers own this DAC and I would love for it to be reviewed & compared against the Fiio E10K and other established DAC's in the sub-$100 space.
The DAC-X6 can currently be purchased for $59USD on AliExpress at the following link: http://www.aliexpress.com/item/feixiang-DAC-2015-X6-febre-HiFi-amp-USB-digital-coaxial-DE-fibre-decodificador-DE-audio/32410721374.html
Color: Black
SNR: ≥105dB
Distortion: ≤0.001%
