Luminair
- Nov 23, 2003
I enjoyed listening to this: http://media.putfile.com/Cereni---Holophonic
I don't know if anyone has played around with 3d audio tests here before, but since threads sink so quickly I figure whoever is reading this right now will enjoy this too
FYI, at the start the guy walks in a circle around you, starting from behind. Then he shakes the matches up and down on either side of you.
My impression of it using AKG K240s is that the sounds in front seem to be up above my eyebrows, and the sound behind seem to be a bit below me. There is less definition behind than in front, possibly just because the recording was done that way. The high height sounds seem fine, and the low height sounds seem to be a bit behind me.
What really amazed me is that when the sound goes up and down, changing your headphone orientation doesn't change the up and down sense of the sound. What I mean is, rotating the cups to be upside down doesn't change the direction of the sound.
This is quite interesting to me as someone who has never put any thought into the way our hearing sense works.
