muziq
- Nov 1, 2013
This.
On the PC, both 48 and 96 are garbled with foobar and jriver in waspi event, plays fine in direct sound.
Android tablet app working so far with no powered hub. But does not like the 48 and 96 files. does not play the 96 and the 48 is garbled.
Looks like a cute little dude. I might get one someday, though I wouldn't mind getting one of the defective ones for less than advertised, since I don't really use anything over 16/44.1. DEAL, GIMME A DEAL
Nice idea! Instead of 'B' Stock...'C' stock
Solves all sorts of problems...could replace my little $39 HiFiMan - HM101 that I keep in my laptop bag (also just a 16 bit solution)
This is the same behavior as I observe:
1. direct sound - all sample rates and bit depths work
2. ASIO4ALL - crackling at 48 and 96 KHz only
3. kernel streaming - crackling at 48 and 96 KHz - stops shortly after play start for 24 bit - runs for 16 bit
4. WASAPI - crackling at 48 and 96 KHz only
Other than 48 and 96 KHz the fulla I have plays fine.
Direct sound works on all sample rates and bit depths because it converts all samples into a certain sample that was set by control panel for Sound in Windows, which is mostly 16/44.1 (CD-quality)
I have a few albums in 24/192 flac, not due to the need of it but because I can't get them in 16/48 or anything else. If go to the control panel on W7, Sound, etc, and change the sound to 16/96, for example, will Foobar play it in 16/96 and, therefore, Fulla play it too? Or do I need to do some more stuff to downsample my audio files?
