Originally Posted by Davesrose /img/forum/go_quote.gif
A headphone driver is not the same as a speaker driver...
...correct -- in a narrower sense it's not the same. However, there's no fundamental difference which would contradict a similar behavior. In a wider sense headphone drivers are in fact mini-speakers.
...and neither are the same as a guitar string. A guitar string goes through much more vibrational force then a headphone driver and doesn't go out of pitch by the number of plucks it receives. It's more likely to change pitch with change in temperature and humidity. |
As an (ex-)(bass-)guitarist I can confirm you that the number and intensity of picks has an influence on the tendency to go out of pitch. And so has the play time. BTW, do you play tennis per chance?
To turn it around....why is 300 to 400 hours a magic number for burn-in then?? |
Maybe people are influenced by the corresponding reports on Head-Fi? But of course 300 or 400 hours is no magic number, just the period after which the sound has stabilized according to people's perception and experience -- in the case of the K 701. I remember that the HD 650 was said to need about 150 hours, and this corresponds to my own experience.
Using this logic: if headphone diaphragms are really that volatile, then wouldn't they keep on changing infinitely? |
Probably they do. But after a certain period the change decelerates more and more and doesn't have a sonic effect anymore. Like a pair of shoes that begins to get comfortable and doesn't change its shape much anymore from there on.
If it gets to be longer than a day, then I can't see how you can remember the finite details of the sonic characteristics of a fresh driver. |
It may not be necessary to remember the sonic details. It may be enough to experience a sonic characteristic that's closer to your personal ideal. In other words, a quality and quantity of sonic flaws easier to digest than in initial state. That said, I absolutely don't deny the meaning of «getting familiar» with a sonic characteristic. But then again, this would imply some sort of longer-term sonic memory as well.
I do believe that a headphone never completely changes its sonic character. I replaced my 8 year old HD580 drivers not too long ago: when I first popped in one of the new drivers, I compared it with an 8 year old driver. Guess what? They sounded identical. My mood and perceptions were the same since I was listening to new and old simultaneously. |
Maybe replacing just one driver doesn't make enough of a difference? Or different headphones have different break-in requirements? Or different people have different (specific) sensitivities?
These days I'm comparing my new HD 650 to my older pair. Out of the box, the difference was like night and day. The new pair sounded extremely bass-heavy to a degree I couldn't accept if it was a definitive trait. Not too surprisingly it turned out that most of the bass emphasis was due to the high clamping pressure of the new headphone. Sennheiser apparently shapes the headband in a way that takes care of a future ware-in process. I don't consider this a design flaw.
Constant equalizing of the pressure by stretching the headband and pulling the earpieces away from my ears reveiled some minor, but still existing sonic differences, but under these circumstances it was hard to clearly identify them. But now that the headband is decently broken in, there are definitely some (not so minor) sonic differences left. The new pair sounds brighter, sleeker, colder, a bit more sterile and also a bit clearer, neither clearly inferior nor superior as a whole, but definitely not exactly the same. However, I still slightly prefer the wamer, more organic characteristic of the older pair.
There's also the real possibility that the two will never sound identical due to subtle design deviations. The only deviation I can detect is the different color of the fabric covering the baffle around the membrane. After all, the loosening of the headband alone already has a clear sonic impact and represents a clearly audible and important break-in effect.
Also, your link for your speaker measurements seem inconclusive. A: your main stance is that it takes well over 25 hours to get beneficial burn-in. B: did you measure the speakers again after leaving them off for over a day (to make sure that they don't return to an "initial state")? |
Yes. The measurements a few days later showed a fall-back at about 50% towards the initial values. I'm sure it will take much less than the previously applied 15 hours to get them «back» to the achieved parameters, though. Moreover a pause of several days doesn't represent the «normal» break-in procedure. But the same applies to the extreme excursion which the drivers had to suffer from to accelerate the process, so final conclusions about the effective and precise break-in behavior can't be drawn anyway. The examples just served to show that vibration (= the normal mechanical stress speaker drivers have to go through during their career) has indeed a measurable impact. BTW, I have measured (other) speaker drivers weeks and months after dedicated break-in, and they have preserved the resulting lower resonance frequencies (close to the nominal values according to the manufacturer).
I haven't spent a sizable amount of time with the k701.....but I have the k501. When I initially complained of the huge soundstage and weak bass, I was told to allow at least 400 hours of burn in. Well listening and burning in for weeks on end didn't do anything to them. |
The K 501 is a fine headphone, and I really liked its strengths, but I wasn't able to ignore its biggest weakness: the thin bass -- which wasn't curable, not even with excessive break-in.
It may still be open for debate if headphones really physically break in, as speakers do without a doubt -- the more so as the measuring differences don't automatically mean audible differences. After all it's rather ignorant to consider (headphone) break-in phenomena unlikely or impossible. In my experience the K 701 has made considerable progress since I first listened to it.
Even if you still don't believe in physical break-in: I believe there are so many people who report initial dissatisfaction and final love that the recommendation to have patience and give this headphone more time to develop (understood as to give yourself more time to adapt) is absolutely justified.
