Hi All,
New member to the Fostex TH900-MKII family here. You can read my journey that lead me to these HP's
here.... it was quite fun..... a lot of work, but worth it.
I have the red cup version. I love the sound of these HP's. I listen to primarily metal and rock, and secondarily EDM and classical, and these just sound great across all genres. I couldn't be happier with the sound.
I'm not optimistic I'll find another pair that sound better than these to my ears (the Denon d9200 also sounds great... but not better..., more like an equal). However, I noticed
these pearl white MKII's at Moon Audio. Anyone know if the sound signature is different than the red ones I have?
edit 12/8: I've been searching and saw in a post somewhere that these new pearl white are the same tuning as the older sapphire ones..... anyone on here have both the red and sapphire? I'm curious as to the differences.?
edit 12/9: I've been looking into it, and I'm going to try to order a pair of the pearl white.
edit 12/11: Pearl white ordered!
Anyone using Dekoni earpads? Any impression for the leather version with holes Vs the one without?
I know you posted this a while ago
@musicday so maybe no longer relevant. So FWIW, yes, I use Dekoni ear pads. I didn't care much for the stock pads, and I tried probably 10 different pads before settling on these..... all the Dekoni ones, Brainwavz, etc and even different brands like Audeze and others. Most of these pads altered the sound substantially. To my ears, all of them - save one - changed the sound for the worst..... usually by either mudding the bass or treble, two aspects that make these HP's so attractive to begin with. The ONLY ones I found to actually
improve the sound were the
"Dekoni Audio Memory Foam Replacement Ear Pads Compatible with Fostex TH-X00 Series Headphones (Elite Sheepskin)". Comfort is only ok, but it's not bad.... still better than stock IMHO. The sound is fantastic.
