Thanks, but don't worry, I only use non-alcoholic wipes on my headphones (and IEMs).Be careful with this! A lot of wipes contain alcohol and other unfriendly chemicals.
Thanks for the ranking.!Comfort-wise, I'd rate the following headphones in order -
- Sony MDR-Z1R
- Sony MDR-Z7M2
- Fostex TH900 Mk2
- Denon AH-D9200
I found these measurements for the Yaxi pads: Inner Diameter: 53mm*66mm. Is it accurate? the same measurement as the stock ones?I'm currently using Yaxi pads with my Fostex, and it feels a little better than the stock ones.
Anyone using Dekoni earpads? Any impression for the leather version with holes Vs the one without?
This , Dekoni Audio Elite Fenestrated Sheepskin really opened the soundstage and made it a bit less bass canon. I liked it , but I like the canons too.Then I think I will be getting the sheepskin for the TH900. I will be using them for the Monitor 5. Thanks for taking your time to write the comparisons above.
I'm not worried about you, I'm worried about guys who are not experts like you who will read your post and not figure it out until they remove paint from their cupsThanks, but don't worry, I only use non-alcoholic wipes on my headphones (and IEMs).![]()
I wouldn't call myself an expert, but more of a veteran, perhaps?I'm not worried about you, I'm worried about guys who are not experts like you who will read your post and not figure it out until they remove paint from their cups![]()
Have you tried the sheepskin not fenestrated? Also do you think pure silver cable will work best for it? What cable do you use of I can ask?This , Dekoni Audio Elite Fenestrated Sheepskin really opened the soundstage and made it a bit less bass canon. I liked it , but I like the canons too.
I tried many cables and I liked the stock cable and the cable from Lawton Audio. If you want a wider soundstage and less V Shape then the Fens , the other one is nice and pretty much keeps the stock sound.Have you tried the sheepskin not fenestrated? Also do you think pure silver cable will work best for it? What cable do you use of I can ask?
Not sure how to read this. Did you mean the fenestrated have wider soundstage and less V shape, and the normal sheepskin is closer to stock?I tried many cables and I liked the stock cable and the cable from Lawton Audio. If you want a wider soundstage and less V Shape then the Fens , the other one is nice and pretty much keeps the stock sound.
YesNot sure how to read this. Did you mean the fenestrated have wider soundstage and less V shape, and the normal sheepskin is closer to stock?
You are just in the beginning of the road... Think in pads, cables and a match DAC and AMP for the beastYou guys are costing me a lot of money
