JKDJedi
I really appreciate the response, and will check into the specs as suggested. (Although they are really tough to find..even from Massdrop)I would be all over the GEC tube but the base of this adapter sent to me is really short, it won't reach the socket, the base that I wanted was an inch long, they talked me out of that and sent me an 1/8 inch base thats way to short, my well is half inch deep.Hi JKDJedi,
I am not familiar with the requirements for your amp and how it is wired. The 6AS7 draws 2.5A and the 6BL7 draws 1.5A so it is a little more for two tubes. In many amps the current draw is the total of all tubes. If the amp is rated for 4A as an example, you could use one 6SN7 (0.6A) and two 6BL7 (3A) for a total of 3.6A.
It should not be hard to find out from the manufacturer or fellow owners if you could use 2x6BL7 (3A) in the power socket, and what kind of adapter is needed.
If you were sent the wrong item, eBay will back you up and you should get a refund.
However, maybe this is an opportunity for you:
The A2293 is a GEC single triode drawing 0.95A, and people report good results with it. Having two of these is similar to one GEC 6AS7. The main reason for getting it is that the GEC 6AS7 is very expensive, and you can get similar performance with a pair of GEC A2293 which are considerable cheaper. A pair of A2293 could cost you around $30-40 shipped whereas a single GEC 6AS7/A1834 could run you well over $400.
Maybe something to think about?
https://www.ebay.com/itm/PAIR-GEC-C...562461?hash=item1cd79e561d:g:VC0AAOSw11BdVqgf
There was a discussion on the Glenn OTL thread about using this tube, but for our purposes we would need multiples of 4, 8 or 12 and it looks like too complicated and expensive to implement; however, in your case you only need one pair.
So as said before, that adapter is just a paper weight. Not what I had in mind at all when purchasing. So enough of the Chinese adapters, I did get a hold of Deyan and he's making a custom adapter as we speak for me, should be ready by Wednesday. And really good to know about the total amp draw of the amp, a very good point brought to my attention, thank you. I'm hitting Big Bear Summit tomorrow guys and gonna let my hair down with some extreme mountainbike downhilling... The adapter will for sure be the last thing on my mind. And thanks again for the help!
