2359glenn
Member of the Trade
- Aug 16, 2010
Hi attmci,
Over on the Elise thread people have discovered wonderful alternative tubes that are spectacular sounding: the EL11 and EL12 tubes.
The EL11 draws 0.9A and the EL12 1.2A. They require special adapters that are a pleasure to use compared to the standard octal adapters - an easy and positive snap-in fit.
The EL11 and EL12 are mainly ST tubes, but there is a smaller and newer version of the EL12 called EL12N. This tube is not expensive and performs almost as well (or as well).
All I can say is that these tubes get everything right and may outshine icons like the expensive 6SN7 variants and the GEC 6AS7.
They were made by Telefunken, Valvo, Philips, Siemens, Loewe-Opta and RFT. The EL12N comes with many names, but they are all the same and only made by RFT.
They are all good; maybe the nod given to Telefunken tubes.
All these tubes can also be combined with other favorite tubes of yours.
IMHO well worth a try if you are so inclined.
They will not work in a WA-22
