Contrails
- Jan 30, 2013
The getter flash is milky white.
I remember reading this indicates a vacuum leak.
Anyway, the slotted columns have arrived. Very very excited, hehehe.
Took a $20.00 gamble on an unmarked slotted square graphite plate 6080WB - eBay seller stated he couldn't verify whether or not the tube would work.
It doesn't - Tube tester revealed a short on the filament pin. Not happy, but at least it's not megabucks down the tube.
Anyway - reason for the post. The getter flash is milky white. Do you think there is a relationship between the filament short and this?
Cheers and thanks
Nathan
+1
White is a sign of oxidation, the vacuum is bad so the tube is pretty much dead now,
Paid $15.00 for a single Tung Sol 6AS7G not expecting much compared to the others in the family I have tried. Hmm... pleasantly supplied. I assume that Chatham and Tung Sol 6AS7G are the same construction with just a different branding? Anyone know a good source for these tubes?
Thanks!
do you have black spots over your 5998's?
At some point, Tung Sol purchased Chatham Electronics, and stopped manufacturing duplicate tube types. So again at some point (early 60's I think) all Tung Sol and Chatham branded 6AS7Gs are essentially Chatham manufactured.
