Hooray of the day. Got this Chatham a couple months ago as one of a pair, and the first triode on it was pegging a dead short. Finally got around to resoldering the pins today just to see if that would fix it, and bingo! I did a full suck'n'solder routine and it tests out perfectly now. Not quite at NOS GM levels but not far from it, and the triodes are within 10% of each other. From trash can fodder to player. The other one I received with it tested fine and I like the sound quite a bit, so I'm happy to now have a solid backup...for free (the seller refunded half my money when I advised them one tube had a short
A little tip for pin soldering for those (like me) that are not at the grand master level of
@Paladin79 .
I've never had any issue getting a good solder connection on the inside of the tube pins. The issue (for me) has always been excess solder that wants to stick to the outside of the pin and then is a PITA to file back down to the original pin profile. Guess what solder won't stick to
and has a
way higher melting point than a 750 degree soldering iron tip? Graphite. As in the business end of a pencil. If you rub some around the outside of the pin (about 1/8" up from the tip is all you need), the solder won't stick to it. Yup, a good old pencil will work fine to see if it helps. Just be careful not to get any
inside the pin especially if you've sucked the old solder out. I got the graphite sticks below as the width makes it a little easier to quickly rub on the pins:
https://www.amazon.com/gp/product/B004BPP4YC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
