RPGWiZaRD
- Jan 31, 2010
lol all i have right now as dsp presets are : k701 and k701 5.1
Well the important ones are still "Default: Balanced (Forward)" and "Default: Balanced (Laid-back)" as these offer roughly same balance as not using ANY EQing / stock foobar settings with all dsps disabled. (With Dolby Headphone I have to EQ out the change it brings to frequency response which those two's settings are for to bring back the frequency balance the headphones have without Dolby Headphone used which is what majority would be "used to" hearing already.
Yea well I personally only use the "Default: Balanced (Forward)" and "Default: Balanced (Laid-back)" as if I need EQing for my headphones I use my soundcard's EQ but I'm simply offering more presets for people that may lack EQ adjustability or don't like to play around with EQing.
I've tweaked the EQ presets for the genres in mind, Classical having the biggest soundstange, more laid-back sound, slightly boosted upper-highs and subbass while pop has more "in-your-face" engaging soundstage with more forward midrange and slightly lowered bass and highs (upside down V-shape EQ) as usual is the case with the pop EQ preset and Hip-hop has especially slightly boosted bass and midrange with a quite upfront soundstage and electronica has a wider/bigger soundstage with better separation with very minor boost in bass and slight boost around mids/upper mids and very tiny bit in the upper-highs etc.
I've adjusted the presets slightly since so will upload those fixes soon.
