danny93
- Sep 20, 2010
Yea you have to navigate to the folder you extracted it to and open the exe file from there (as your other foobar2000 install will open if you click on a mp3 file). If you want it replacing the other foobar2000 you simply put the folder into the exact same place as the other foobar2000 which you can move/rename temporarily or whatever and then it will become your default foobar2000.
I deleted the other foobar already, I´ll just install it again (stock) and then replace folder. Thanks man, and any idea how to get crossfade working, cant get it to work in prefrences.
