Earbones
- Dec 21, 2013
SO... Got my Stellia yesterday. First impressions follow:
1. They couldn't have splurged a little on packaging and build materials? Kidding. Jesus Christ.
2. These things are detail monsters, but I don't have a headache after several hours. How's that work?
3. Best. Focal. Mids. Ever.
4. Sure, highs are a little rounded off from the Utopia, but that's why I always preferred the Clear to the U. But again, more detail than the Clear, so kind of a lovely middle ground.
5. Bass quantity is identical to the Clear. What's different is that for the first time ever in a Focal, I'm getting grip... Firmly in Audeze LCD-series territory grip. And if the fit isn't perfect... some boominess is present. That said, I've done this rodeo with the Elegia. Some Focals require just the right fit for bass to present as it should. In the case of the Elegia, it would disappear if the fit wasn't right. With the Stellia, it can get boomy. So I played around with the fit, and found the sweet spot... Same bass quantity as the Clear, loads of grip, and zero boominess. Bass detail and articulation is slightly superior to the Clear. Anyone who is getting boom from the Stellia should play around with the fit.
6. At 35 Ohm, Easier to drive than the 55 Ohm Clear... but by a larger margin than the 20 Ohm difference would suggest. Slightly easier to drive than the Elegia, which are also 35 Ohm. The Stellia plays very well with the Sony NW-ZX507. With high gain engaged on the 4.4mm out, I'm listening at between 22 and 35... out of 120 volume. Plenty of head room. Obviously does well with Chord Mojo and Sony PHA-2A as well.
7. I've found all Focal cans benefit tremendously from a balanced set up. But the Stellia even more so.
8. As a bat-eared individual who doesn't need a lot of volume... I have to say, these do really, really well on low volumes. Sometimes a headphone's sound will just kind of dissolve if it's not played loudly enough. Not these. Detail, highs, mids, bass, even soundstage are all fully present at super-low volumes. Zero loss. Kind of amazing.
