An odd one here - and bear with me as only got my headphones yesterday - all works fine with my Astell SR25 using AptX and the headphone jack but the minute plug in the USB C cable it works but I cant alter the volume - either via the headphones buttons or the SR25 - Is it a bug or am I missing something obvious ?
It has to do with how DAPs handover USB control. Don't function the same as with phones. Typically volume and other functions are disabled when using USB out on most DAPs. It's not an issue with either one of your devices
Anyone using a headband cover on their Bathys? I got the Dune colorway in, and the microfiber/suede headband is just asking to absorb all the dirt/oil in sight. Also, I had a bit of a hotspot issue with the OG Bathys headband after some time, so hopefully a cover will alleviate that slightly.
Do these still have the issue when ran wirelessly on iPhones where the volume jumps up in fairly big increments (which was the case when I tried these back when they were first released) or have Focal increased the number of volume steps through a firmware update?
They look decent and the fit seems good, I might have to order one. Thank you for that, really appreciate this. That will definitely extend the life of the original headband
