audio dilettante
Would you mind explaining the difference between the bitrate and kHz.Yes that would do the trick! At this point it would more be what kind of adapter you want (straight, U type adapter or even L type adapter) I would go for the one that fits your needs best. I personally use the adapter that came with my phone and it works flawlessly with my BT dongle.
Make sure your BT adapter goes up to 24-96KHZ (I've heard that the Sennheiser BTD600 is capped at 48khz). I recommend the KB8P that can be ordered directly from Ali Express and can also come bundled with its own USB-A to USB-C adapter!![]()
I was thinking of getting a new phone that supports aptx adaptive but am now concerned it may have the same limitation as the BTD600 i.e. 48hz although I don't know what the consequence would be in terms of sound.
