roines1987
Simlpy put. BATHYS are great!
Yeah, I'd argue the Sony's without the EQ sound pretty rubbish. I've got an EQ that I'm happy with, but would be interested in seeing your settings to see if I can extract a bit more juice out of them.sony needs eq I can post settings later if you're interested
The Sony's are great at ANC, but sound quality is so so. I do have a pair of XM5s that I only use for flights and similar, but not much else. Only keep them for their amazing ANC ability as they are a life saver on a plane with very noisy people close by. IMO the XM5 are more like a 120-180$ wired headphone sound quality wise as long as they are powered on with DSP correcting for acoustical deficiencies.You are never going to get everything with a Bluetooth ANC headphone so you have to decide what's most important. ANC - Phone Calls - Music. None of them are perfect and ANC degrades sound no matter how you slice it. With a little EQ Sony's are great and much less than the Bathys. They have much better noise cancellation and look less Geeky if your wearing them out and about. They are also less heavy. It will also greatly depend on the kind of music you listen to. Many shops have 30 day returns so just go with your gut.
I'd defo say they're far from wired headphones in that price range. If you pickup an Elegia for $300 it will be noticable more detailed, have a wider soundstage and better instrument seperation than Bathys. Add Dekoni pads and it'll have a better tonality too.Bathys is more comparable 400-600$ range wired headphone IMO when in DAC mode, but you are paying for ANC, DAC, AMP etc. with the Bathys so the price is fine. ANC is passable on the Bathys in that they drown out a good amount of low frequency rumble, but their passive isolation leaves a lot to be desired so they let through quite a bit of background noise in the midrange to lower treble.
I always found the Sonys sounded muddy and somewhat boomy, especially after using the more detailed Bathys. The Bathys ANC is good enough and doesn’t seem to effect the sound quality as much as some headphones. However the Sonys are good value, but the Momentum 4’s sound better (to me) in that price range.Get a pair of Sony for ANC and then get something for really listening to the music you enjoy. There is a lot of hype around the marketing of the Bathys but that is to be expected. And for some it is just great.
Not SciFi, but wishful thinking because of the limits inherent in the technology. Think of MP3 music vs. high-resolution music.but the concept of Bluetooth being comparable to wired is still in the realm of science fiction?
High end Bluetooth and high end wired is like night and day in difference.
Bluetooth headphones and wired headphones in the same price range, most definitely the wired ones will be better. Some wired headphones will need some power to get the most out of them. So connecting them to a phones 3.5mm jack might not be enough to get the best out of them
This day might come. But as of today we are very very far away when comparing BT vs wired in sound quality.I'm no expert. But to the people saying Bluetooth will never beat a wired connection: this has been the year that AI came of age (or at least a primitive form became ubiquitous to the public). Are you honestly saying that it's possible for humans to create a technology so advanced that it can surpass our pwn capabilities and even threaten our entire existence, but the concept of Bluetooth being comparable to wired is still in the realm of science fiction?
