emklap
- Mar 21, 2014
FiO X5 Mk1 replaced now by FIIO X5IIQuick survey: What source do you use with your FLC8S?
So just get the KZ cable?For those of you looking for a smartphone cable that is compatible with the FLC8s, I've finally found one that isn't custom.
Go to:
https://www.amazon.com/dp/B0728DZN4F/ref=cm_sw_r_cp_api_C4bOAb9892PRK
I'm not talking about "fits" like some have said the TF10 fits, I'm talking about ACTUALLY fits. It's like buying a cable for your FLCs', and getting a free Dual-Dynamic+Dual-BA quad-driver Chinese headphone with it!
Just thought I'd share after spending a couple hundred on FLC cables....
Go to:
You mean you haven't heard of the KZ ZS5?Nice find - thanks for sharing! Those pins look a little short in the 4th photo. Do they make a solid connection with the FLC8S socket?
Also, those IEM shells look suspiciously like those of the Andromedas Do they sound any good??
Word of caution: the NA TF10 pin fit will be hit & miss due to tolerances. My first set (Arete) were extremely tight to get onto the FLC8s and I'm wary to remove them now. My second cable (Lune) were a better fit, tight but not as tight, to get on a second set of FLC8s. Other connector types I've ordered through NA also have been hit & miss.Try NullAudio Arete MkIII. Much better than original cable. No microphonics, sleeved, copper bodied IEM connector. Also cheaper than LMUE cable replacements - just 99 SGD. Use UE TF10 connector by customisation.
https://www.null-audio.com/collecti...e-series-mkii-replacement-cable-for-earphones
But aren't the pins too long?I have yet to find a TF10 connector that does not stretch/risk stretching the flc8 to an unhealthy degree. KZ ZS5 has had no ill-effect.
