sodesuka
- Feb 6, 2015
@sodesuka, ouch on the phone! Are the silver wires stiffer than the originals? I could mod the Flare myself. The tricky part is getting a good cable that fits in the body slot with the proper tightness.
It isn't fun soldering the little speaker driver. Already did that once due to stupidity.
Thanks
No, it's quite flexible, pretty much as flexible even though I made it 4-braid, I bought it from here http://www.ebay.com/itm/Pure-Silver-9999-Stranded-Litz-Wire-29AWG-Teflon-Audio-Cable-Tonearm-Rewire-DIY-/111053284574?hash=item19db4aa4demaO-rvt9vKr6jjdiq3WbRLA
Relatively cheap compared to 'boutique' cable.
Oh I know what you mean, I failed once and had to buy spare drivers from flare since I was using some stiff 28awg solid core cable, worked well for a few weeks, and then it just broke at the solder. Then one of the driver went kapoof on another resoldering.
The one on ebay above is litz stranded 29 awg cable, which seems to work well, we'll see how it'll hold up. I have another pair of spare drivers ready if anything happens this time.
