xoxiax
- Sep 2, 2015
@xoxiax
1) weirdly enough, isolation is more or less the same as in old ones. I still have to test them outside but for now rest assured it's very good or great.
2) From what you're saying R2pro should already be good enough for you. But yes, there's more midbass and subbass than in R2A's - there's more body and more punch while retaining or even improving clarity and resolution. I definitely wouldn't call them basshead IEMs but they're definitely not bass-shy either. I would like a tad more subbass and a little less midbass but it's great the way it is.
I can already tell you that Campfire Andromeda have probably better treble and Sony MDR-EX1000 have still a little better subbass but overall they both are inferior to Flare Pro. You can't have it all but with Flares you get plenty and then some. Highly recommended.
Thanks!!!
Sounds really promising, hope they launch soon a cheaper version without all the extras i don't need. I just want the bettered little flares with a stronger fixed cable. How i'd love some Flare Audio's information about it....
