Crazy*Carl
- Aug 8, 2009
No.
For a meaningful ABX comparison, volume should be adjusted in hardware only, not software, and the resulting volume difference between the samples needs to be less than ~0.25 dB (perhaps even less).
Originally Posted by kmj2587 /img/forum/go_quote.gif
In practical terms for me and the kind of music I tend to listen to, this translates to my classical library being 90% flac while the rest is about an even mix of flac and mp3.
Why not software ? If the adjustment is done using 24 bit output format (which is possible with anything other than the lowest end DACs and onboard audio), it has insignificant effect on the audio quality, and it allows for very accurate matching easily.
If software is used, the output is no longer bit perfect relative to the file being played.
Further, since volume need only be adjusted for one file of each comparison, only one of outputs is being degraded.
I doubt the quantization noise of 24-bit audio is anywhere near audible.
If software is used, the output is no longer bit perfect relative to the file being played. Further, since volume need only be adjusted for one file of each comparison, only one of outputs is being degraded. Suddenly the comparison made is not the comparison desired.
Additional ABX test would be required to test that hypothesis before it could be validly assumed for the comparisons being discussed.
Additionally, most codec comparisons involve 16-bit files, not 24-bit. The more changes made to the files being compared, the less general and meaningful the results are.
....isn't replaygain applied on both tracks?
Just FYI, I did try it myself without replaygain and dsp...
"I replaygained both tracks in foobar, the difference was half a decibel or so."
Half a decibel or so volume difference is too much to compare sound quality, because the files should be identifiable by volume alone.
That's not me == ...my post at #78
...I've said I didn't use any replaygain or dsp, the process was just encode and compare
Yes, but ReplayGain adjusts volume in 1.5 dB increments.
0.00 or parhaps a very insignificant value.. replaygain scan on both tracks return same values
