FLAC vs 320kbps
post-8098065
Post #16 of 120
Jaywalk3r
Seattle
Seattle
Take one of your FLAC files and convert it to 320k. Then highlight both files, right-click -> utilities -> ABX two tracks.
You need to do it at least ten times I'd say as to rule out luck.
Given a single pair of tracks and ten ABX comparisons, one would need to correctly identify X eight times in order to reject the null hypothesis (the null hypothesis being that there is no discernible audible difference between FLAC and 320 kbs for a particular listener on a particular equipment setup listening to a particular song) at a 95% confidence level.
post-8098082
Post #17 of 120
Selenium
Phoenix
Phoenix
Well I'm just trying to get him started on the right path, not overwhelm the guy.
post-8098091
Post #18 of 120
manveru
Every time this conversation pops up in a thread, it always severely weirds me out that so many people say there's no discernable difference, or that it's "slight," or you "need the right gear."
post-8098106
Post #19 of 120
jiff
Now when it comes to WAV files I hear a difference over FLAC and 320.  As for just FLAC and 320 its nothing that makes me say "wow that sound much better" and my source as well as gear is fine.  FLAC does sound a little better than 320 its just not worth the extra space they take up in my pmp.
post-8098114
Post #20 of 120
vyyye
That's funny because WAV and FLAC produce the exact same sound.
post-8098289
Post #21 of 120
olear
I use 320 MP3, if I did use FLAC my Sansa Clip Zip would weight too much with the larger files.
If you added 32GB memory card, would you then have enough space for ~1000 songs?
post-8098294
Post #23 of 120
Watagump
Twizzler King
Orange County CA
Orange County CA
I dunno, I only have like 200+ songs. Adding a memory card + FLAC, OMG, my Zip would be too heavy to even walk with it.
post-8098309
Post #24 of 120
olear
I think there's a graph I can plot showing the correlation between post count and the propensity to say yes
Anyways, I don't think I'd be able to tell, but I've never tried ABXing at 320kbps. I've only gone up to around 200-250 (vbr), and I could tell an incredibly slight difference but didn't really care. This was all with modern Lame versions. Ogg Vorbis and AAC/M4A encoders both perform a bit better than Lame. In full disclosure, I didn't have quite as good of equipment as I do now, back when I did said test.
Huhh?
post-8098314
Post #25 of 120
olear
Very much appreciated.
I've spent so much time deciding on which IEMs and new at this.
post-8098325
Post #26 of 120
olear
Can someone PM me on which sites have quality MP3 320 kbps and procedure to use to download onto a clip using Windows.
Thank You
post-8098381
Post #27 of 120
Willakan
It is probably easier to just make your own from .flac files or similar using LAME.
post-8098384
Post #28 of 120
Assimilator702
Listen for yourself. I know you already have Foobar, so check out this component: http://www.foobar2000.org/components/view/foo_abx
I'll be trying that out myself.....I use FooBar220 but never used that plug in.
I add maybe 10 FLAC albums to my collection daily so that will be a nice ultility to use along with Flac Tester and Audio Checker.
post-8098470
Post #29 of 120
olear
I find Foobar not very easy to use.
post-8098478
Post #30 of 120
dwinnert
I can hear the difference, but still use 320kbps....the sound difference doesn't warrant the effort for me. 320kbps is still very musical to my old ears.
