Flac 16 bit or 24 bit Qobuz
- Thread starter damians
"....... the testing of theories against the evidence obtained"
I don't see much indication where you undertook that bit of the definition, not robustly at least, robustly as would be required to state with the level of conviction that you do that current scientific understanding is nonsense and you know better.
It seems you made plenty of observations and established your theories then assumed your theory was right and therefore trumped science and went on your merry way.
That is what most audiophiles do and is why you have no trouble finding people that agree with your theory that science knows nothing and your ears are better gauges of fidelity.
Oddly, as I have said a few times but it is ignored, that is the theory that ridicules the very same technology that provided the files that contain the audio data that they are listening to when they say the science is garbage, that is nonsensical.
Diet Kokaine
Almost all Audiophile "Myths" have a basis in observation.
Observation as carried out by millions of people all around the world.
Good science would try to integrate this massive amount of data into further refining existing "Theories".
A good scientist is always refining the scientific method. The idea that you already know everything there is to know, especially in the face of such vast amounts of anecdotal evidence is stupidity disguised as intellectual authority.
Instead of arguing endlessly on Audio forums, I wish some of the people here would practice the scientific method and get to the experimentation part of this debate.
1. the systematic study of the structure and behavior of the physical and natural world through observation, experimentation"
I have done the observing and I have done the experimenting.
I find the existing theories wholly lacking.
science
noun1. the systematic study of the structure and behavior of the physical and natural world through observation, experimentation"
castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
Good science does not try to willingly integrate bad testing.
Observation is assumed to be proper observation with control over as many of the extra variables as possible that might affect the result, so that we can actually verify causal relation between changes to the variable we test(here would be 16 vs 24bit encoding of the same 24 bit file and something to test audibility between those files).
Anything else that's been ignored in your "observation", and might affect the result, will make the 16 vs 24bit inconclusive. It's obvious, as we do not want to say that 16bit caused a change if some other variable actually did it.
At least that would be the logical explanation. In practice, most people know better before they even do anything, and because they're very stronk and smart, so they don't need complicated testing methods to know everything and always be right.
step 1, use a naive understanding of yourself and the world around you.
step2, feel like it's super easy to know stuff in that naive simple worldview.
step3 profit!
It's not the setting of science, it's the setting for a physics troll meme.
step3 profit!
Could you explain the detailed experimenting that lead you to your conclusion.
What you are debating isn't a theory it is the merits of different digital data formats that were developed for a specific purpose after a great deal of testing.
Your theory in essence is that science doesn't understand the function of something that it it was used to design.
Why don't you take an hour and try the 16 bit versus 24 bit online test that is shown in that video, that should be a breeze for you and your system despite that the results for just about everybody else that did it were no better than guessing and chance.
Davesrose
- Oct 20, 2006
You should probably have not attempted to get into this. Your analogy has no basis in reality. You can't play a 4K file on a 720P TV set. 720P sets are part of the HD standards-digital TVs that support 1280x720P or 1920x1080P resolution sources (as well as traditional "SDR" colorspace that's 8bit). UHD is a newer standard that has 4K and even 8K resolutions, as well as a higher dynamic range (current TVs rendering 10bit color space while video codecs will allow up to 14). 4K has gotten popular as displays get larger, and our eyes exceed the specs of current HDR dynamic range (visual detail is determined by resolution, contrast range, and optical qualities of the lens).Think of it like 4K and 720p. The higher resolution of 4K doesn't mean that you're now able to see in Ultra Violet.
Human hearing has obvious limitations (Upper and lower frequencies) , but resolution is something different.
How do you quantify resolution? How do you quantify timbre? Soundstage? etc etc etc
If you play 4k files on 720p TV sets, the extra information is useless. Same principle applies here. It's not a mantra, it's a fact.
These analogies don't apply with audio, because human hearing for music reproduction does not exceed CD quality (music is not mixed to have a dynamic range above CD quality, and resolution meets hearing for any age group).
Diet Kokaine
I've said everything that I have to say on this subject.
Peace.
Peace.
Diet Kokaine
Blah blah blah.Good science does not try to willingly integrate bad testing.
step3 profit!
It's not the setting of science, it's the setting for a psychics troll meme.
It's fitting that you're the moderator here.
Child like tantrums and petulant rants are a hallmark of this religious cult.
sunjam
Banned
AKA sunjam2, sunjam3
Not everyone hear hi-res the same (and not every system reproduce hi-res the same too)Hi everyone, I've been subscribing to Qobuz for some time now to listen to quality music. I've done several tests but if I listen to the same songs in 24 bit and 16 bit I can't hear the difference, it seems to me that both have excellent quality. I entered the qobuz account in the USB audio player PRO app and listen to everything in bit perfect. As headphones I have the Beyerdinamic DT 770 pro and the DAC is an Ibasso DC06pro. Can you hear the higher quality of a 24 bit flac? or am I the one who has hearing problems?
To simplify the analysis, have a look at the following picture:
Both the blue wave and the red wave show a sine wave with different dithering noise (due to different quantization). Do they sound the same?
Some would say yes, and some would say no.
As an analogy, based on Newton's second law of motion, the net force acting on an object is equal to the product of its mass and acceleration (i.e. F=ma).
Do you think F=ma correct in describing motion?
If your answer is yes, then I bet you would find both the blue wave and red wave would sound the same.
The proof is indeed in the pudding but the pudding is not in what you or your girlfriend think you hear, it is in the actual facts!You guys can say whatever you want. The proof is in the pudding.. I hear what I hear.
Really, how? What is wrong with your speaker setup and IEM rig?People that are streaming music on lower quality distorted setups might not be able to tell the difference between bit rates, but on my speaker setup (and IEM/portable rig) the difference is clear as day.
Theories and text books is where digital audio comes from!You guys are stuck in theories and text books.
Indeed it does but you seem oblivious to how your analogy is actually analogous! 192/24 is analogous with “4k files” and speakers and human hearing are analogous to “720p TV sets”!If you play 4k files on 720p TV sets, the extra information is useless. Same principle applies here.
You’re joking, please explain how science made this observation of digital audio. You think maybe ADCs, CD players and DACs grow on trees, are mined or were observed orbiting the Earth? You don’t seem to understand what science is, nor apparently have you even thought about what you’re claiming! If you don’t know the difference between “basic science” and “applied science” then why not look it up in an encyclopaedia (try Wikipedia here) BEFORE posting nonsense here? “Basic science” is “to explain observation” but in audio we’re dealing with “Applied science”, because digital audio obviously does not exist in nature. And lastly, if observation really did take precedence, then are you really claiming all the observations of Bigfoot, fairies, mermaids, ghosts, the Loch Ness Monster, alien abduction, poltergeists and all manner of other nonsense take precedence over proven scientific theories?!Good Science is always subservient to observation.
Science is a cogent way to explain observation. If Scientific theories and observation are in contradiction, the observation takes precedence.
Sure, science is subservient to Bigfoot and Santa Claus. Thanks for the enlightenment!Science is subservient to observation, not the other way around.
Which is effectively that you don’t know what science is, that observations of ghosts and mermaids, etc., take precedence over science and that you’re willing to argue all that in an actual science discussion forum! lolI've said everything that I have to say on this subject.
It’s your choice to belong to the religious cult that places reported observations over the science/actual facts and your choice to exhibit the hallmarks of that cult. However, that is obviously not acceptable here!Child like tantrums and petulant rants are a hallmark of this religious cult.
G
Diet Kokaine
"Sure, science is subservient to Bigfoot and Santa Claus. Thanks for the enlightenment!"
Sound Science Strawman gibberish.
@gregorio well done.
What do you mean “@gregorio well done”, you’re the one who’s done it! You’re the one who claimed science is subservient to observation and there’s been any number of reported observations over the centuries, from fairies to Bigfoot, the Earth being the centre of the universe, etc.Sure, science is subservient to Bigfoot and Santa Claus. Thanks for the enlightenment!"
So “yes”, it is Sound Science gibberish, because you are posting gibberish to Sound Science and it would be appreciated if you desisted!
G
Diet Kokaine
Sorry I can't take anything you say seriously.What do you mean “@gregorio well done”, you’re the one who’s done it! You’re the one who claimed science is subservient to observation and there’s been any number of reported observations over the centuries, from fairies to Bigfoot, the Earth being the centre of the universe, etc.
G
I'm not even reading your insane posts.
But you can take seriously the BS you’re posting, of science being subservient to observations (Eg. Bigfoot)?!Sorry I can't take anything you say seriously.
How did you quote and respond to it then, did Bigfoot read it to you? lolI'm not even reading your insane posts.
G
Diet Kokaine
Stop quoting me. I have zero interest in having this back n forth with you.
I'd much rather discuss the consistency of squirrel droppings with a homeless badger.
That'll be a more productive conversation for me.
