Yes there is, because “being actually there” is just one specific location and never (as far as I can think) in the case of a large acoustic ensemble the location that presents the highest fidelity. With a recording on the other hand “being actually there” can mean several/many different locations at the same time, including the locations with the highest fidelity.
What is the location with the highest fidelity? What original are they faithful too? They are the original.
But a double bass in a perfect recording room is NOT “seen as the reference” for anything, it’s not even necessarily seen as the reference for that specific double bass in that specific room (with no other instruments), because just the variation of the musician’s performance from take to take is significant, and it most definitely is not seen as the reference for an entire orchestra!
I never said it is seen as an reference for an entire orchestra. I said its an reference on how this Double Bass should sound. And this is something that is defined by humans.
Someone (mostly the company who makes the double bass) has an intention on how this double bass should sound. They have to test and verify, that it sounds correct. They can only verify that, if they have a reference on how it should sound.
_This_ is how the double bass should sound.
Because an Orchestra is an ensemble of many things, you can not archive High Fidelity of the Double Bass as it has to sound good in the overall thing. So at this point, a new original is created, the performance. A new reference is created.
But there is no fidelity here, because you are listening to the original. You can not be faithful to an original when you are the original.
And the Instruments are not Faithful to their own reference, which is, as you stated correctly, wanted. They are not striving for highest fidelity in terms of reproducing the single instrument sound. They are creating a new reference that something can be faithful too.
No it does not, the fidelity can be as high as we want. We can (and do) specifically close mic certain single instruments in an orchestra, depending on the piece and instruments in question, and achieve the highest fidelity possible of single instruments. Although with some instruments we do not want very high fidelity, what we want is how the musician intends it to ideally sound to an audience. Lastly and most obviously, the fidelity of an orchestra is in terms of that orchestra (performing that piece, in that venue, at that time), not in terms of a single instrument. Again, fidelity is the faithfulness of the recording or reproduction to the musical event/s (IE. How closely does the output match the input). It is NOT how you feel an instrument should sound or even how that instrument will actually sound in a different context (say unaccompanied, in a different ensemble or in a different room). Fidelity is not subjective!
G
As you said yourself, Fidelity means being faithful to the original. I never said something different, i even said 2 times, that fidelity is not the right word and i mean quality.
So i make it clear once and for all to prevent you from explaining it to me 3 more times
"I meant sound Quality, not Fidelity"
And yes. When you want high fidelity (i even said that in my last post) you have to reproduce all the distortions and the noise faithfully. And that was my critic in the first place.
You call this noise wanted, that is very subjective. I do not want to hear coughing people, footsteps and distortion. That is an subjective opinion, absolutely right. I do not strive for High Fidelity in terms of classical recordings.
And hence, i believe, my terms stay correct. If you want highest quality (Least Distortion and Noise) with an high fidelity in terms of instrument reproduction, an high fidelity classical recording is not giving you that. Distortion and Noise are part of the experience. Its wanted by some, not by me.
I've been to more than enough live concerts and i think most, but not all, will agree, going live is an experience and not an sound quality enjoyment.
You enjoy the sound quality with an professional live recording (that usually tries to not capture the noise and distortion as they sacrifice fidelity for the sake of quality) or with the studio album. You do not go into an concert hall to enjoy sound quality, its all about experience and performance. And that can't be reproduced as you need more than sound to do this.
I've even been to classical concerts where i had to wear earplugs as it was just too loud and no longer enjoyable (actually most of them). I did enjoy it with earplugs, but of course, wearing earplugs, it was no experience that i connect with the term quality. And of course, i wear earplugs on every normal concert.
