- Aug 18, 2007
Is that the Wolfson in the Gamma 1 or Gamma 2 DAC? I'm mobile and can't look it up right now.
Originally Posted by tomb /img/forum/go_quote.gif Just an FYI from someone who also sells a PCM2702-based DAC (Bantam): there is no such thing as a "PURE" connection to the TI PCM2702*. It produces its analog output centered at 50% of Vcc. Vcc is the analog voltage supply. Typically, this is the +5V of the USB voltage, or some regulated portion thereof. It's quite simple to regulate the +5V down to +4.75V with significant benefit in noise and performance. This has been done for years on the AlienDAC and the Bantam, with oodles of test data that can easily be looked up. The main point, though, is that the voltage center of the analog output (the music signal) is positive voltage (typ, ~+2.5V). That means that any PCM2702 implementation must have output capacitors, or some other buffering device to remove the voltage offset. "PURE" from the DAC output connections is impossible. On the other hand, there is a Wolfson DAC chip, specifically the WM8524, that uses a charge pump to produce analog outputs centered at "0" volts. This means that in the case of the Wolfson 8524, it IS possible to make connections directly to the DAC's analog output, with no intervening circuit components whatsoever. The new grubDAC has been designed that way (full disclosure - I sell that one, too). I'm not certain how many other mfrs have started using this chip in this way, but it's entirely possible that if claims are made for a "PURE" output using this chip - it may, in fact, be true. *Also note that TI has declared the PCM2702 NRND for quite sometime - Not Recommended for New Designs. IOW, the chip will be phased out at some point in the future. |
