[size=xx-small] Quote:
Originally posted by CRESCENDOPOWER
Jude,
Besides not matching up well with every headphone on the planet, having no crossfeed, and burning yourself when you give it a hug are there any real negative comments you can make? I guess I'm just trying to find an excuse not to buy it. |
[/size]I still haven't had a chance to try it with other low-impedance headphones, so I don't want to say too much yet about whether or not it's specific to the HP-1, or if it's something to do with low-impedance headphones in general. I'll say more about this as I try more headphones with it. The Grado SR-80 will be the next low-impedance headphone I try with it.
So far, in the positive column: Sennheiser HD-600, AKG K-340, Etymotic ER-4S.
In the good-but-not-great column: Grado HP-1.
Actually, it just occurred to me that I haven't yet tried the Sennheiser PX-100, PX-200 or PXC-250 with it, and the first two are 32-ohm.
Negative comments? Well, things that one must seriously consider with the Twin Head Mark II, of course, are price [size=xx-small](~$1900)[/size], size [size=xx-small](especially if you want to put some distance between the amp and power supply)[/size], weight [size=xx-small](I'm not sure how much the pair weighs, but they ain't flyweights)[/size], heat output [size=xx-small](I wouldn't recommend putting them in a closed cabinet)[/size], and power draw [size=xx-small](I believe the pair draws about 150 to 200 watts from your wall outlet)[/size].
Sonically [size=xx-small](other than the lack of crossfeed)[/size], with headphones that pair up nicely with it [size=xx-small](and, in particular, the HD-600, which is downright heavenly with it)[/size], I can't think of any negative sonic comments to make about the Twin Head Mark II. I'm going to be trying some tube rolling with it soon, because if it can get even better....
So far, it has shown itself to be a
very impressive, standard-setting amp, and one I'd recommend without hesitation.[size=xx-small] Quote:
Originally posted by evilcthul
Hey Jude,
I know how to stop it burning when you hug it. Buy the production version with tube cage just be careful of the wife...
In all seriousness you talked about the umbilical cord a few posts above. Is it hard wired? If so, what's the length etc?
Let me guess, you've ferrited it? |
[/size]I generally don't care about how a piece of gear looks, but even I wouldn't dare cover these tubes up with cages! That would have to be considered some sort of aesthetic sacrilege.
The umbilical cords [size=xx-small](plural, as there are two)[/size] are maybe a few feet long [size=xx-small](I haven't measured these yet)[/size]. They are hard wired on the power supply side, but can be detached at the amplifier side, which, as Joe stated, will allow for power supply changes, which could be interesting. And, no, I haven't ferrited the cords yet -- can you believe that? Hadn't even occurred to me, but now that you brought it up....
I will place some ferrites on them later today.[size=xx-small] Quote:
Originally posted by Joe Lau
Hi ! How about a full solid stage power supply just simplifier it to
CLC circuit ? May be I can made a power solid stage supply and send it to Jude later. Oh ! Twin Head seperated power not only benifite on noise but also Upgradable or downgradable , kidding by change of power supply. Oh ! May be I want to check the configutation on cable is it suitable for MG-Head Mark II. I try to steal money from your pockets. |
[/size]I'm not sure what the sonic benefits of a solid state power supply would be [size=xx-small](if any)[/size], but I would be interested in trying it if you decide to make one, Joe. I would guess it would likely be smaller in size [size=xx-small](is this correct?)[/size], which could be one advantage for those who simply can not find the physical space for both the Twin Head Mark II and the PS1.
I want to commend you on the Twin Head Mark II, Joe -- you hit it clear out of the park with this one, man.
