stilleh
I’m using Apple Music on my X7 II and it works fine for me.
And proven wrong
And proven wrong
X7II is definitely has smoother and responsive OS compared to N5II. But if you are looking for a better Android experience on a DAP, also consider Hiby R6 Pro.@stilleh & @Peter68 - thanks for your help. Just to confirm, Apple Music works with the latest FW?
Seems like the DAP for me. Generally, does Android run pretty smoothly on it? Also, is the Bluetooth reliable?
I have recently had three Cayin N5IIS's that, while sound amazing, all failed in one way or another and have just returned the third one for a refund as it is obviously a problematic product - would you consider the X7II a good alternative to that?
turn off, take the cards outOk well I'm remembered how to wipe partition and reboot but seems this new update won't let me re scan both my cards and just says fiio music stopped working.... very frustrating.
.turn off, take the cards out
restart, hard reeboot as you have done
turn off, put the cards back in, restart
resacn
that's worked 4 me before.
Reformat the cards and load everything up again. My X7 has ruined two 200 GB Sandisk cards.Honestly fiio i cant even scan cards now! Apart from playing from folder the rest is idle grrrrrrrrr
