Glad it helps!
I don't know if performance mode is using a lot more battery, didn't made any test. But there so much difference in sound quality that I don't want to hear anything about this "balanced mode". I bought my X7 for good sound, it was not cheap, so I will certainly not choose to degrade sound for battery saving!
Now that you see "Performance mode" is solving your ringing issue, maybe you should also test if it solves the EQ issue?
And finally, a message to
@FiiO:
Dear FIIO, I think that giving choice to consumers by allowing them to choose between "balanced mode" and "performance mode" is very nice : thank you for that, choice is always good and much appreciated.
But at the same time I cannot understant why you did choose "balanced mode" to be the default one : it is a verry bas idea!
When I did test my X7 for the first time, you should be aware I was close to cancel my purchase for another DAP because I thought it was not that better compared to non FIIO DAP, some of them beiing cheaper
Until (lucky you!!!) I found this "performance mode" in the menu, which made a huge difference in sound quality.
That being said, I'm pretty sure you are loosing customers because they are testing your product in "balanced mode", because they do not know a "performance mode" does exist.
In a word : in a future firmware update, "performance mode" should be default preset.
