peter1480
Did/do you have the old x7 too? If so, could you try the 400gb in the old one? Thanks a lot!
no not at the moment but I never had a problem with a 256 when did so I'd guess it may work
X7 dac isnt exactly lower end. On the contrary its quiet nice and you need pretty decent hps and amps to transmit everything its capable of.
I am not saying here from point of view of measurements but from what i hear.
Adding an amp thats not good will result in colouration that you can actually hear and make out. Also it will mask some subtle dynamics and details. You want to hear them i assume thats why you made this investment in first place.
Since you own planars, but i dont have experience with those models. Most full size hps will give better impact and a more present and robust sound on adding an amp. Make sure that amp is a good one and transmits all goodness x7 is capable of.
Thank you so much for your answer. What would you consider a good portable amp that can be paired with FIIO 7ii?
I have the PM3's and PM2's the X7ii powers them just fine, both SE and Balanced. I also have Audezee LCD2, but I use AM2 when I listen to them. Never use extra amp, even though I have some.Thank you for your answer. Would you pair it with anything? I have oppo pm3 and audeze el-8 closed back.
I would look at reputed amp builders. Jan Meier, Ray Samuels, Head amp comes to mind.
While their offerings may look confusing, most of their amps should impart no flavour. So you can choose anyone.
I am myself debating between meier quickstep, ray samuels sr71a, headamp pico power. If you want to narrow down to models.
Thank you so much for the information!I have the PM3's and PM2's the X7ii powers them just fine, both SE and Balanced. I also have Audezee LCD2, but I use AM2 when I listen to them. Never use extra amp, even though I have some.
Peter, have you tried 400 gb sd + 256 sd card ?no not at the moment but I never had a problem with a 256 when did so I'd guess it may work
Thanks for the great news!Yes that combination is working using fiio player and folder view the main way I use the x7ii.
