We have been to that discussion before - the removable battery is not going to happen on FiiO not because it can not be done, but because 1) there isn't a cellphone battery with large enough capacity to reach minimum required battery life set by FiiO, For example, X5 already has a 3700mAH battery while Galaxy S5 battery is only 2800mAH - a 30% lost of battery capacity. and 2) it increase the overall size due to the need of a battery bay. Have you seen the picture where DX50 / DX90 user trying to fit an extended battery onto their DAP but can't close the battery bay anymore and have to use the silicone case to hold the battery inside? There is no such thing as a perfect solution to the problem. You get some, you lose some.
Also, who said you need to send it back 'every years'? A typical Li-ion battery can last over 3 years on normal usage.
why can't they make a detachable battery and sell it as a part on their website??
It's 100% possible. They make a customized detachable battery and sell it separately so users can carry extras and replace them when they want.
I didn't say it should be a cellphone battery. I said
something like a smartphone battery that is easily detachable and accessible.
This can be a perfect solution to this problem.
You don't lose a thing by making battery detachable and selling extras. Developers will make even more money by selling extra batteries on their website. Users will save more money and time by getting an easy access to batteries. If I truly love the dap, I would buy three extra batteries to use on travel. I believe many others would do the same.
Do not make a quick judgement and say something is impossible before you even try. That kind of mindset deters decent DAP development.
Do not even reply to this thread, please. I don't know what makes you think you can argue over this but your point of view is totally narrow minded and not understandable.
1.Making a battery detachable will not increase a size of a DAP. what makes you think like that? Does your cellphone gets bigger because of its battery?
2. Making a battery detachable will not reduce battery's life and capacity. what makes you think like that? Does your cellphone's battery last less because of its detachability?
3. Making a battery detachable will only make people like this DAP more. You'll be able to carry extra batteries all the time. who said to you that you must use a cellphone battery?
4. Making a battery detachable will not make developers lose something. who said to you that all of your cellphone developers lost something by making their cellphone batteries detachable and selling extras on Ebay?
5. Making a battery detachable will not make YOU lose something. What's your point?
6. Making a battery detachable will not make any of us lose something
7. Making a bettery detachable will not make YOU lose time and money so don't worry.
8. Making a battery detachable and easily accessible will save YOU time and money.
Once we get this feature, we will never have to worry about its battery life at all.
