FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Jun 12, 2015 at 3:00 PM Post #3,976 of 18,020
OK so you need a good cable kit and soldering iron for the job.
Jun 13, 2015 at 7:35 AM Post #3,978 of 18,020
  If Neutron or PowerAMP as music player apps are allowed you can simple access over a samba share from a WiFi hard drive.
Just recieved WD My Passport Wireless. It works great with my HDP-R10 and Neutron using DLNA, which PowerAmp does not support. So i think it will also work with X7 in future.
Just got extra 1 GB on my R10:)
Jun 13, 2015 at 2:15 PM Post #3,979 of 18,020
GB or TB?
Jun 13, 2015 at 5:30 PM Post #3,980 of 18,020
http://www.soundstageglobal.com/index.php/shows-events/the-show-newport-2015-irvine-usa/186-the-show-newport-2015-features/585-the-show-newport-2015-headphones
Jun 13, 2015 at 5:59 PM Post #3,982 of 18,020
Uh... it does not look like originally designed... what is that edgy gap near screen? Why edges are shar cut? :/
Maybe titanium material was a better idea... (well titanium alloy would be awesome). Looks a bit too thin... means battery will be smaller...
Jun 13, 2015 at 6:05 PM Post #3,983 of 18,020
Did you not see the picture James posted? I think your seeing a wide angle lens making it look thinner than it is. Just look at the RSA balanced out connector. Can't get much thinner than that.
Jun 13, 2015 at 8:29 PM Post #3,987 of 18,020
Jun 14, 2015 at 4:22 AM Post #3,989 of 18,020
It has aptX I believe, so although that's just a codec it should improve the stream quality.
Jun 14, 2015 at 4:26 AM Post #3,990 of 18,020
Actually, didn't James say they dropped aptX because of the cost of licensing? I know it says aptX on the first page but I think it was dropped.
Edit: Found it......
sorry not APT-X cause the cost. not the hardware but the APT-X asked very high licence fee.
