WitzyZed
I wouldn't mind vibration feedback for battery level alerts, especially in my pocket.
it is a connector for battery. and there are not second MicroSD slot. very sorry.
Thanks - we can all chill out now and move on. Doesn't matter anyway - the X7 will be awesome
There are 128g MicroSD card and I believe there will have 256g MircroSD card. so the capacity is not a big issue . and we may release couple version, for example, maybe a 128g build in memory version. also you need to consider whether the X7 can handle so many
sound tracks in the data base.
128gb internal would be awesome.
if you could also do 256 gb internal, that would be even better, even if i would have to pay more.
money
money
For me 64gb would be fine to keep costs down, no less though.
personally i'm fine with 16GB. even 8GB would be enough for me.
That one should be for the battery. I think the display connector is on the bottom right next to the cardslot.
The thing that makes me wonder is: why the heck is there a vibration-thing on the righthand side? It's neither a phone nor do you need to receive haptical feedback for notifications. The only purpose could be vibration feedback when tapping the screen like some early generation cellphones with resistive touchscreen have had (though the X7 should have a capacitive touchscreen which wouldn't make it necessary).
So the vibration feedback is not necessary ? it is ok and quite easy to us to remove it from the PCBA!
i totally understand, no problem then!
i really wish that x7 is going to be as great as it is looking right now, and the most important aspect, to sound good!
also, i know that you are having X5II in plans, i was wondering if you would make it have a sabre DAC and sound at least close to x7?..
Not Sabre DAC in X5 II
