I wanted to try out this mod, but there are few concerns, as I have 0 knowledge in modding
1. The talks about the issue with 1.0.9 - this only happens when the player is left on, but with screen off? It's not happening when I fully power it off?
2. Is it easy to go back to official firmware?
@Cabrio - could you please describe the sound differences? I like the 1.1.4 sound, but sometimes the highs are a bit "metallic" (especially with voices). Is it better on the 1.0.9 version?
1. Happens when wifi is turned on and screen is off. Doesn't matter if you turn off wifi again, only way of fixing it is by rebooting with wifi off. Does not drain when device is off.
2. As easy as reflashing 1.1.1 with the same procedure!
I haven't done enough audio tests with both firmwares to confirm your last question though
