Fiio X5 - Custom/Modded firmwares
Nov 11, 2014 at 11:46 PM Post #511 of 2,615
  Yes, Theo, I was on fw 2.2 before and it was very difficult to get to the card selection w/o many steps. Now it's so easy and it looks a heck of a lot better! Now I can't easily fault the X5 on anything at all!
Burn in, olddude, hahaha!
Well, whatever the case may be..I'm glad you're enjoying the device more now
Nov 12, 2014 at 1:05 AM Post #512 of 2,615
Nov 17, 2014 at 2:07 PM Post #516 of 2,615
I just ordered an X5.
Did the Matrix theme get completed? I respect the work you dudes put in on here and take nothing for granted. Very appreciative of what is clearly a lot of work.
You should have a go at making your own theme. It really isn't as difficult as you'd think, it can just be a bit tedious sometimes..but fun nonetheless
Nov 17, 2014 at 8:28 PM Post #517 of 2,615
I made a webpage in html xhtml and some json but right now I am
Building Christmas and having a mega party and of course the real Santa is coming....or it's a $400 costume.....but who would pay that
So I am slammed and will get the X5 in a week or 2 so is it alright if I use one of the themes? I'll have a try myself as I am into creative expression but on the X5 that will have to wait a bit and some of the themes like the Matrix just look so badass,
Nov 18, 2014 at 1:44 AM Post #519 of 2,615
I used a couple, just seeing what I liked/what made the device easier to use, then took one and adapted it (with Loquah's kind help unpacking and packing it back up again)  and posted it here.  Play with them, there are lots of choices.  Then, if you like, try adapting one.  No reason to reinvent the wheel.
Nov 18, 2014 at 3:10 AM Post #524 of 2,615
Nice job on the firmware updates, I like how the direction of the wheel has been corrected in the right orientation that it should be going in. (I was getting very confused)
I have been using firmware 2.3 and it and it's sounding excellent with the eq off, it is sounding very balanced with a dynamic bass now, it would be worth doing a upgrade port on.
And keep up the good work. Well done to those involved.
