CH23
- Nov 24, 2012
The problem with rockbox is not knowing the chips instruction set, but as there have been devices that already run android on this cpu, it should be possible.
Also just flashed the AP100 firmware to it.Could work, need to fix some images probably.buttons not recognised, won't work.
I could never bring myself to flash firmwares just like that... I'm too afraid of bricking my X5.
I found a thread called "unofficial ClockworkMod Recovery 5 for Ingenic JZ4770/JZ4760 tablets" on XDA, and post 479 may basically mirror what the procedure would be to start up something on the X5.
It might be something similar to this:
Put X5 in USB Boot Mode
Install USBBootTool's drivers and run it
Select JZ4760 device
Load up whatever files to be flashed to the X5
Connect X5 to the PC via USB cable
Files will be flashed.
But then again, FiiO X5's partition structure must be wildly different from an Android tablet (Just system partition for fw + cache? vs the system/data/cache layout of Android), wrong files will definitely break the X5, and I don't know of any method of returning the X5 to original firmware once firmware is completely swapped out.
I think I'll refrain from experimenting with the X5 USB Boot mode for now until we can get more information or a solid way of restoring the X5.
I'm definitely not flashing things through the tools. I do believe the basic "flashing firmware" is like a BIOS and should never be erased if you flash using the X5 itself.
Found this on the rockbox site:
http://www.rockbox.org/wiki/FiioX3
http://www.rockbox.org/wiki/FiioX1
Which lead to
https://github.com/Rockbox/rockbox/tree/47d053735be0233a9821fdfdfd1d0a4651b6e61f/utils/jz4760_tools
