Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
- Thread starter xLoud
New Fiio Owner
it is a known bug
Thanks, I didn't want to search the whole thread.
This is really weird because I get a message in English, and I'm running the same FW.When playing a track and favouriting it using the heart, it gives me a message in Chinese even though I am running my X5III in English.
- Oct 2, 2015
Dear friend,
Please send the internal_sd\FiiOMusic\crash folder to our support mailbox. And in what certain operation would this issue happen?
Best regards
I will send it tonight. Happens when I load FiiO music app.
Hi All
Are any of you using closed back headphones? If so, which ones are you using?
Regards
Darren
Regards
Darren
Dear friends,Hi @FiiO
Yesterday I found a bug in firmware version 1.1.7 (not the beta version), when DAP is bellow 15% (without power saver, no idle timeouts) on balanced mode, music stop playing when screen shuts down resuming automatically on screen boot;
Its is not usual to have DAP without any charge but nevertheless is it a really annoying bug, this did not occurred on non balanced output (since only start using balanced yesterday after receiving the F9 )
Thanks
Seems failed to reproduce the issue you met in the same firmware. Could you please update to FW1.1.7(8.4): http://x5pack.fiio.net/X5-ota-eng-20170804.zip for try.
Best regards
Oletros
- Nov 12, 2015
I´m using OPPO PM3Hi All
Regards
Darren
Thanks. I'm currently using the Meze 99 Classics. They both seem popular at that price point.
Focalor
Dear friends,
Best regards
Hi @FiiO
Like stated by @ailean is a little it or miss issue; Again yesterday after a long day use without issue, at night after boot issue started again (battery at 80%) then after another boot no issue at all (only difference between usage was booting DAP with or without balanced output plugged)
I will download given version and validate if issue still occurs;
Thanks
Gerryhatrick
- Nov 9, 2015
BW P7 sound great if you like a solid bass
Yamaha HPH MT8
Thanks for the reply. I am thinking about the wireless version, as Twister6's review say the there is no need to get the wired version as the wireless is so good.
https://twister6.com/2016/12/18/bw-p7-wireless/
- Jan 30, 2011
Hi All
Regards
Darren
FiiL Diva for Bluetooth (with NC) - they are fantastic for travel. And the HD630VB - Sennheiser knocked it out of the park with these. I just wish they were a little lighter.
Dear FIIO,
I reported to FiiO months ago that 32-bit floating point playback using
the Android AudioTrack API is messed up. They did not fix it until now
it seems.
Best regards
it seems.
Best regards
Hi All
Regards
Darren
I use Beyer Dynamic T51p
