Riley Beale
- Jul 9, 2016
Thank you for the kind words. As for the Opus, it is a dedicated music player (as of right now, a future iteration MIGHT be "fuller" Android. The sound from it was just luscious. Thicker (not the best terminology...), with a better reach down low; I was impressed with the overall note of the #1. As for sound stage, the x5iii was slightly wider. I do not consider that a downfall of the #1. It provides a slightly better quality of sound (for my tastes, which are on the warm side of the equator), with a better bass reach.
It's hard to put into words, but the overall sound of the Opus appealed to me more. That said, I do have my own x5iii on the way. The appeal of the x5iii to me is that I can get onto the internet, and do other things. Yes, not as smooth as my Smartphone, but a nice option. If I can find an M5 or #1 used at a reasonable price, I will purchase those, too. If nothing else, but for comparisons sake.
All four are stunning units, approached markedly dipolar...simple DAPs vs DAP-surfers. You cannot go wrong with any (in my opinion only).
Thanks for the detailed information. It is very helpful. I prefer less warmth than I used to. Slightly warmer than neutral is about where I like it now I think the Opus 1 is probably a bit too warm for me as I gain more audio experience. I like that the bass goes a little lower on the 1, but the overall tonality is probably not for me at this point. I probably would like the X5 3 and the DPX1A soundwise the best. I do not want real forward mids, but prefer them not too be v or u shaped really either. A slight recession of the mids is okay, but nothing more. I have the Shure SE846 and find the mids are too forward and the treble is just way too rolled off and smooth for my current tastes. My tastes have changed a bit since I got into this hobby. I like bass extension, but overall clarity and balance just as well now with a slightly warmer than neutral sound with crisp airy highs.
Thank you
Riley
