nekromantik
- Jul 30, 2009
hmm will try re install.
ES explorer suggests to you - install Solid Explorer or Root Explorer instead of me. I'm waste and destroy me right after installing another explorerI use the custom kernel version 3.11 2016. When I launch the es explorer application, the player hangs on a black screen. Sometimes it can hang up until a full reboot from the button. There is no such problem on version 3.2.
This is a question for Brooko. On the X7ii thread, you recently mentioned your X5iii gets more use than your X7ii because of it's warmer tonality and smaller size. In your review of the X5iii you said it was slightly let down by its amp section. Have you changed your opinion, or just learned to live with it?
Would you characterize your player's power button as mushy or as clicky?My fiio X5 III does not turn on. I have tried to press and hold the power button for long periods of time and it does not work or plugged into the network or by usb. Can somebody help me?
I've tried everything and nothingWould you characterize your player's power button as mushy or as clicky?
If you have ever turned on the USB-Debugging option in Developer Options (enabled by clicking build number several times in "About Device" try connecting it with usb and in a terminal window enter "adb reboot" .
If that was never done, can you confirm that you've left it connected to a wall-usb charger for a period of time with an assortment of cables, so we know it's not the cable falling to charge it?
I'd hope your microUSB socket wasn't damaged in some way. If your power button is mushy, with the button facing downwards, take some high % rubbing alcohol and lightly soak a Q-tip, rub it around the button, and then spray some compressed air tightly around it.
Best of luck.
This happened to me, I tried everything I could think of. New cables, chargers, etc. Finally I opened the back of the unit, jiggled some things around to make sure everything was seated correctly and closed it back up. It started right up. Not sure if it was coincidence or real. I suspect that the battery connection isn't good or the battery is starting to fail. Worth a try if you have the proper tools.My fiio X5 III does not turn on. I have tried to press and hold the power button for long periods of time and it does not work or plugged into the network or by usb. Can somebody help me?
Nope - different uses. X5iii for IEMs and earbuds. X7ii for harder to drive full sized cans. Still love my X5iii - one of the best DAPs FiiO released IMO - especially with JK's kernel.
What type of tools I need? thanks!This happened to me, I tried everything I could think of. New cables, chargers, etc. Finally I opened the back of the unit, jiggled some things around to make sure everything was seated correctly and closed it back up. It started right up. Not sure if it was coincidence or real. I suspect that the battery connection isn't good or the battery is starting to fail. Worth a try if you have the proper tools.
I bought this one https://www.amazon.com/gp/product/B00SURH7W4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1What type of tools I need? thanks!
Without it, you're not even a man.
