Hi, I've been using Revision 1 of the UTWS5 for around a year now with zero issues. Normally I use them with my Android 12 phone (aptX Adaptive, latest firmware v1.7x).
However, for some weeks I experience a strange behaviour with the UTWS5 where the overall stability and connection range is very low - like 2 meters at max before the stability is affected or the connection cuts out completely. From the time when I purchased these I remember that I had flawless stability at over 10 meters distance (even through walls) with the same smartphone. Is this some kind of technial issue? I wouldn't assume that stability degrades gradually over time. The battery is still good for more than 5 hours of listening. Within the limited range the device behaves completely normal.
EDIT
Flashing an old firmware and updating to the latest again seems to have solved the problems for now.
EDIT
