Yes, enought room for volume with the utws5Question for anyone with a u12t and a utws5 or go pod. Do they get loud enough? Thank you.
[FiiO UTWS5] True Wireless Bluetooth Earhooks as Usual,Coupled with Independent AK4332 DAC
- Thread starter FiiO
- Tags
- fiio fiio utws5
As a user of ifi go pod and utws5, ifi go pod get louder, on utws 5 I always need to crank the volume to max so my phone Stat at 30-40%Question for anyone with a u12t and a utws5 or go pod. Do they get loud enough? Thank you.
samirfjain
- May 22, 2015
Ok thx. Lil curious cause i have a u12w on its way. Only use wireless and need it loud. Recently bought a m9 and was terrible with shure tw2. Even on the 215 setting not nearly loud enough. Oddly the se846 is plenty loud on the same setting i guess sensitivity makes a big difference w these new wireless adapters. Thx again all.
So I just got these, updated firmware, and paired with Fold 4. I'm seeing no LDAC option in bluetooth codecs on the app, what gives? My phone works with LDAC fine with other devices.
anli
I guess it is needed to allow the codec via FiiO Control app.So I just got these, updated firmware, and paired with Fold 4. I'm seeing no LDAC option in bluetooth codecs on the app, what gives? My phone works with LDAC fine with other devices.
i have, its not on the list. All I can see is aptx, aptx adaptive, AAC and LHDCI guess it is needed to allow the codec via FiiO Control app.
anli
@FiiO What is the last beta with LDAC (probably experimental) support?
Did you enable the option in the phone Bluetooth setting?i have, its not on the list. All I can see is aptx, aptx adaptive, AAC and LHDC
If you have not done this already, do the following:So I just got these, updated firmware, and paired with Fold 4. I'm seeing no LDAC option in bluetooth codecs on the app, what gives? My phone works with LDAC fine with other devices.
Download the firmware from this post.
After successfully updating, unpair (forget) the UTWS5 from your phone, and repair again.
Do a factory reset from within the FiiO Control App.
Enable LDAC from the App.
Unpair and repair your UTWS5 again.
Enable LDAC both in Bluetooth and in the Developer Options on your phone.
Thanks, I tried all of these, nothing works.If you have not done this already, do the following:
LDAC isn't even in the list of optional bluetooth codecs on the app, so I can't select it. It's enabled in developer options of my phone and i use it with my XM4.
I'm on v1.5 firmware which it says is the latest. Damned shame as id like LDAC
The latest firmware version is v1.74Thanks, I tried all of these, nothing works.
You can download it from the post I've linked above.
Ahhh thank you for being patient, I was using online firmware upgrade.The latest firmware version is v1.74
LDAC activated
anli
Hi. Does PEQ is supported and stable (doesn't reset) with 1.74 firmware?
tirrorex
- Mar 2, 2016
Hello, looking for some adapter as my utsw5 is mmcx, anything good for 2pins?
I want to sell my fiio iems and use my blessing 2
The adapter i got from amazon was unclipping itself from the iems.
samirfjain
- May 22, 2015
Oeaudio is the best. Clear is avail on amazon. Black on there website. But i tried the adapter which many people like versus the 2pin version of the utws 5. Preferred the 2 pin.Hello, looking for some adapter as my utsw5 is mmcx, anything good for 2pins?
