[FiiO UTWS5] True Wireless Bluetooth Earhooks as Usual,Coupled with Independent AK4332 DAC
Nov 13, 2022 at 9:33 PM Post #1,711 of 2,559
So when will the UTWS5 will be updated to get LHDC 900Kbps? I see its sister product the FW5 have it, and using the same QCC5141 + AK4332 setup as UTWS5.
Dear friend,
We have reported this feedback to Qualcomm and LHDC. Currently, the support of LHDC are still trying to solve this issue.
Best regards
Nov 14, 2022 at 7:41 AM Post #1,712 of 2,559
I went back on a Redmi note 10 pro and I can confirm that it keeps the 900kbps setting going in and out dev options, and I can hear a tonal shift when switching to another bitrate, these things are not happening on a xiaomi pad 5. I cannot tell for sure if the higher bitrate is effective (old ears) but I think it could.
Nov 14, 2022 at 8:44 AM Post #1,713 of 2,559
And you are using utws5 for the output? Because no phone could keep 900 kbps setting or some could but it was no sound after this. And this was with many poco, xiaomi, oneplus and nothing phone i have tested. Only Mi pad 5 could keep 900 kbps setting and there was playing, but there was no tonal shift as you say so i believe it's fake .
Nov 14, 2022 at 9:49 AM Post #1,714 of 2,559
Yes. I can set 900kbps on pad 5 but when I exit dev options and go back in, it reverted the setting, and as you say I can't hear any bitrate switch. On the note 10 pro it works.
Late tonight or tomorrow I will try a curve with pumped treble on wavelet
Nov 17, 2022 at 1:41 AM Post #1,716 of 2,559
On OxygenOS13 lhdc still not working:slight_frown:
looks like oneplus with their oxygen os is not from the bunch of brands that wants to support lhdc. For me it's like some competition going on between some brands. So if xiaomi is fully suporting this codec, oneplus don't want to. For us users such things is always a bad thing. And when i upgrade my old oneplus (when it still had its personality) it wont be oneplus. I want to have phone that fully compactible with utws5 and it's codecs.
Nov 22, 2022 at 6:05 AM Post #1,717 of 2,559
So my left earhook seems to have died overnight. It can't be manually turned on by holding it's power button, the case indicates only the right one is charging. I've cleared paring as well now, and since then my phone (Pixel6Pro) hasn't been able to find either one of the hooks.
The case itself also refuses to go into pairing mode, no matter what I try.
Contacts have been cleaned on both, and I've charged the case overnight, but as of right now, my UTWS5 is a paperweight. Really frustrating, and I'll have to either use my UTWS3 again, or my BTR3K until I get a solution. I've contacted my seller about the issue, waiting for a response.
Nov 24, 2022 at 2:41 AM Post #1,718 of 2,559
Dear friend,
Sorry to hear about that.
If the seller fails to help, please contact support@fiio.com with the receipt attached. Thanks in advance!
Best regards
Dec 8, 2022 at 1:42 AM Post #1,720 of 2,559
Hi, are there any updates on if a newer version like UTWS7 are coming out soon? I'd like to wait for a new model if it's about to release.
Dear friend,
No, thanks for your interest.
Best regards
Dec 8, 2022 at 11:51 AM Post #1,722 of 2,559
QCC5141 platform now has LDAC codec working and some products have it since mid 2022 (source: 52bluetooth). I hope FiiO can test and release an update to fix LHDC and add LDAC. If this become true, then FiiO will have the best product with triple Hi-Fi codecs.
This please. As a Samsung user, LDAC would be great. Please Fiio!
Dec 8, 2022 at 12:09 PM Post #1,723 of 2,559
I don't think @FiiO cares about giving the UTWS5 any support anymore. It is an old product in their catalog and they would rather you buy newer products. After some initial talk from them about new software updates earlier this year, they have bee SILENT about it ever since. I'd look to purchasing something new instead of waiting for @FiiO to give us updates.
Unfortunately, this is the reality with most, if not all, Chi-Fi companies.
Dec 8, 2022 at 1:01 PM Post #1,724 of 2,559
I sincerely hope that @FiiO will keep supporting and developing the UTWS5 further because there is nothing else like it on the market.
Please, @FiiO listen to your customers :)
